Lm7 dbw to dbc
Old Mar 26, 2017 | 07:58 PM
Tcs13's Avatar
Default Lm7 dbw to dbc
I recently bought a lm7 out of a 2005 Tahoe which came stock with a drive by wire intake/tb on it. What all do I need to after the new intake and tb is swapped on?
Old Mar 26, 2017 | 08:47 PM
Lsxford's Avatar
LT1swap.com has some good info on doing this. Check out his page its got everything you need to know
Old Mar 26, 2017 | 09:25 PM
Project GatTagO's Avatar
The better question is why would you want to do that? If you have all the electronics, DBW works awesome.
Andrew
Old Mar 27, 2017 | 02:59 AM
Tcs13's Avatar
I didn't have all the electronics, but I decided to meet the guy and go get the old intake/tb. DBW it is then!
Old Mar 27, 2017 | 09:12 AM
JoeNova's Avatar
Restricted User
The intakes themselves are pretty much the same. You will just need a throttle cable, throttle cable bracket and a throttle body with sensors. Then you'll have to grab the wiring for the TPS and IAC from sensor to PCM and pin them into your harness.
Last, you'll need a PCM that can control DBC.
Old Mar 28, 2017 | 03:16 PM
Tcs13's Avatar
any idea on what pcm to use?
Old Mar 28, 2017 | 04:33 PM
tim wellington's Avatar
Default pcm
99-02 service number 9354896 or 12200411
