pcm electrical help please! exciter on alternator miswired...
Old Mar 30, 2017 | 09:22 PM
alanon's Avatar
Default pcm electrical help please! exciter on alternator miswired...
Hi guys,
I apologize if this is in the wrong place. I need help with electrical, and not sure where to post it. I tried the PCM Diagnostics group, but apparently my post was disallowed.
I've got a problem. My alt is drawing power 100% of the time. More precisely, the exciter is. I've confirmed it by cutting the exciter line, watching the draw, and reconnecting it.
I've got an LS1, 4L60E, and PCM from a 1999 Camaro SS in a restomod. I'm finding errors in the wiring that was installed that I have to correct.
I've found wiring diagrams on Autozone's repair assist page, but the diagrams don't confirm switched power. From what I see, wire# 15 or #61 needs to be used from the PCM to run the alternator's exciter. Tracing wires, I found that #15 is blank on my PCM. The wire in #61 is a brown with white stripe wire, and has no power on it; switched or otherwise.
I think the solution is to cut the line from the always on and put it to a switched power source; and I think it's supposed to be that #61 wire, but can't find anything to confirm it.
So my questions:
-is there supposed to be switched power on line #61?
-can I put it to any switched power source? Including one that is already wired?
-prob best to inline fuse it?...what size fuse would I need? stock alternator; a/c style serpentine setup.
Thank you in advance!
Old Mar 30, 2017 | 11:35 PM
Hi-Po's Avatar
When I rewired my car I simply put switched power with a resistor inline to the alternator. Worked great. I forget the resistor rating. If you have trouble finding the rating I can dig it up for you.
Old Apr 1, 2017 | 09:38 PM
alanon's Avatar
thank you Hi-Po. Why the resistor?
What switch power source did you tap into so as not to overload or fry anything?
Old Apr 2, 2017 | 06:38 PM
Project GatTagO's Avatar
470 ohm...
Search the conversion forum. This has been covered....a lot...
Andrew
Old Apr 4, 2017 | 09:22 AM
alanon's Avatar
ok thank you
Old May 21, 2017 | 06:48 AM
Old Geezer's Avatar
There's an electrical forum, for this kind of ??
