67' C-10 L59 Swap Help!
If you've never built an engine before, it's not that hard. If Joe Bubba Redneck can do it on the back porch of his trailer, you can do it, too.
What takes is planning, and careful attention to detail. There are lots of books available through amazon, and lots of videos on you-tube. Relax, take your time, and enjoy the process.
As you choose parts and pieces, don't be cheap. Spend the money on good parts that will last and make a difference. Never buy cheap parts, they're too expensive.
Look up Sloppy Mechanics on Youtube, Matt is a member here under the id as Denmah. He has a great following on FB and youtube. My son has a STOCK bottom end 5.3 with 862 heads, a VS Racing 7875 turbo, a cam upgrade (I don't know the specs), Seimens Deka 80 injectors, homemade hotside using stock truck cast manifolds, an ebay intercooler and 2.5" piping, He had a local tuner do the tune on a stock ecm using HP tuners. He added a Walbro 400 pump to the stock tank and uses -6 push lock lines for the supply and return. Dyno proven 550 rwhp. Plans are to go high and push it a bit harder with the boost.
Junkyard 4l80e with a Transgo HD2 shift kit is in my son's truck and works great with the billet triple disc lock up convertor. Matt has a 6.0 Colorado that has made over 1000 rwhp with the same trans a junkyard.
Junkyard 4l80e with a Transgo HD2 shift kit is in my son's truck and works great with the billet triple disc lock up convertor. Matt has a 6.0 Colorado that has made over 1000 rwhp with the same trans.
Will the 4l80e work with my 5.3/4l60e harness?
