6.0 to th400?
Old Apr 2, 2017 | 05:59 PM
ls72nova's Avatar
Default 6.0 to th400?
So I bought an adapter to mate my 2005 6.0 to a th400. I notice my motor has a flange sticking out the back of the crank and isn't flush like some I have seen. I haven't took the motor off the stand yet but I tried pulling the flex-plate to look it over. Does this look right? Or do I just leave the flex plate on and bolt the adapter to it?
Old Apr 2, 2017 | 07:20 PM
dec010974's Avatar
Default Lq4/9 to a TH400
Hello ls7nova. I hope all is well. To install the the spacer properly, you current flex plate must be removed. Please check your application. Some lq4/lq9 comes with the correct flex plate so a spacer isn't needed. Was the 6.0 connected to a 4L80e prior to removal from the donor vehicle? If it was then you don't need the spacer. Please verify this. My previous vehicle 1971 c10 had the lq9 bolted to a th400. Good luck.
Old Apr 2, 2017 | 07:36 PM
ls72nova's Avatar
I don't know if it was or not, these I ask is all the LS cranks I have seen didn't that lip sticking out by the flex plate, they were flush
Old Apr 3, 2017 | 11:27 AM
dec010974's Avatar
I have a spare, 5.3 at home, on an engine stand. can you provide pics? if not ill post one.
Old Apr 3, 2017 | 01:22 PM
learning91's Avatar
I have a van 6.0 sitting here its just like the pic....i'm just not sure of yr
Old Apr 3, 2017 | 04:08 PM
ls72nova's Avatar
Like I said, I have an adapter in the box already but the end of this crank doesn't look the same as the rest I have seen. The flexplate itself is flat. To me it looks like there might be a spacer behind the plate already from the factory
Attached Thumbnails 6.0 to th400?-photo484.jpg   6.0 to th400?-photo646.jpg   6.0 to th400?-photo533.jpg
Old Apr 4, 2017 | 12:12 AM
Lsxford's Avatar
That engine looks like it was in front of a 80e and already has the spacer built into the flexplate. You can take you converter and hold it up to the flexplate and make sure it fits the hole correctly.
Youre gonna have to hog out the convertor bolt holes. I always like to put the engine and trans together and make sure the converter fits correctly, should be a small gap between flexplate and TC with trans bolted to engine. About the size of a small washer, if its much more than that ive seen ppl put washers between the 2 but ive never had to do that. You wanna pull the convertor out of the pump a very small amount, like maybe 50 thousandths
