Wiring help
Old Apr 11, 2017 | 10:41 PM
Hubbledd's Avatar
Default Wiring help
Just installed a 2009 LS 6.0 LY6 in a 2007 Silverado replacing a tired 4.3 six. I received the complete wire harness, ECM and TCM. I also received the center wiring cube (?) that fits into the underhood stock fuse box. I'm at a lose as to where to began. Everything I've read is in regards to early swaps where all the newer accessories are not dealt with. Any help getting me on the right track will be highly appreciated.
Old Apr 12, 2017 | 08:59 AM
ryanleiker's Avatar
LT1swap.com
and
I like the Haynes Manuals wiring diagrams from the parts stores
I would assume many of the wiring pin locations and colors are the same between those two years.
You may try to post in the PCM Diagnostics and Tuning section... or jump over to the sister site PerformanceTrucks.net
Your LS1Tech username and password should work to get you into the forum to post your thread over there... good luck
Old Apr 12, 2017 | 04:36 PM
CutLS's Avatar
Are you trying to wire your new harness to the old fuse block of the 4.3? You could find the connector diagram of the harness to know which terminals go where but you will probably need to get a need fuse box with the proper internal wiring or have a few external fuses that don't go into the factory fuse block.
Old Apr 14, 2017 | 04:40 PM
Hubbledd's Avatar
Default Wiring help
Yes, when I pulled the 4.3 and harness, about the only piece I remember removing involving the harness was the cube from the center of the fuse box. One of the major items attached to the new harness is a similar "cube" with what appears to be all the positive (heavy gauge) wires for the engine. Am I just wishful thinking that somehow this new connector will somehow fit the old fuse box? Thank you for responding.
