No tach signal output
Old Apr 20, 2017 | 08:46 AM
brianbajnauth's Avatar
Default No tach signal output
Hey since I finished my swap in to my 87 gta trans am my tach worked for a couple day and then just stopped. I had two 10k resistors on the tach signal output wire form the pcm to my stock tach wire in the car. The tach just stopped working just like that. I tried hooking up two different after market tach nothing works. I hooked up my obd2 scanner and it shows the rpms. So Ecu is getting signal out not putting out any signal. Any ideas?
Old Apr 24, 2017 | 10:47 AM
Anyone?
Old Apr 24, 2017 | 11:42 AM
Aston Tibs's Avatar
I only used one 10K resistor in the line. Check your connections and make sure something didn't come loose.
Old Apr 27, 2017 | 12:06 PM
Thanks for the reply
I checked and rechecked the connections. Is it possible that the pcm is not giving a tach output for some reason
Old Apr 27, 2017 | 12:21 PM
JoeNova's Avatar
Restricted User
I've never used a resistor with an aftermarket Tach and an LS and never had a single issue.
Old Apr 27, 2017 | 12:28 PM
imma_stocker's Avatar
Things rarely just stop working for no reason.
Trace the wire from tach to PCM, every foot or so check the wire for voltage. Also verify the pull-up voltage source is still live. I don't know why you need 2 resistors, that might be causing other issues.
