Ls swap problems
Old May 1, 2017 | 08:54 AM
hotrodharry's Avatar
Default Ls swap problems
I swapped a 07 truck 5.3 into my 69 Camaro with a turbo. I have a new harness from GM Performance with a new E67 computer, the computer has been tuned for my setup. The car will try and run but goes dead after a couple of seconds, sometimes it will crank and run for about 10 seconds and then just shut off, kinda like it's in a limp mode. Fuel pressure is good and all harnesses are new. It has new coils, plugs, and wires. It's giving me a po355 code, I have swapped coils and checked all connections the grounds seem to be good also. Asking for help please....
Old May 2, 2017 | 10:08 AM
dan96z71's Avatar
Sounds like VATS are still involved. When you swapped coils did the code change?
Old May 2, 2017 | 08:11 PM
rockusaf's Avatar
Try unplugging the MAF as well if you have that installed. Mine wouldn't run right with the MAF plugged in, like yours it ran for a few seconds and died, but it ran fine if I unplugged it. Once I got the intake tubes installed and plugged the MAF back in it ran like a champ. Cheap/easy possibility and worth a try.
Rock
Old May 3, 2017 | 06:04 PM
-TheBandit-'s Avatar
What type of MAF are you using? Is it the truck MAF that came with the engine or a card style MAF?
On mine, I had to switch the pink and black wires on the MAF connector due to changing from the LY6 screen style MAF to an LS7 card style MAF. I had a similar issue where might it would sometimes fire for a second or two, then die.
Old May 4, 2017 | 07:48 AM
L92 OLDS's Avatar
All good advice above. Connect an OBD scanner to your diagnostics plug and check the MAF signal for correct range. If you don't have a scanner you can buy them cheap at Harbor Fright.
Unplugging the MAF sensor will put the ECM in default mode (speed density) and it should run. It may take a few attempts to get it to catch.
Old May 4, 2017 | 07:51 AM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
$5 says he is using a custom OS with the turbo and the MAF is absent, however the MAF was not failed properly (ie not reporting the code) allowing the ECM to go into SD.
