Gen IV motor question
Old May 1, 2017 | 10:33 AM
rastaman's Avatar
Default Gen IV motor question
I bought a Gen IV 5.3L truck motor w/tranny for a very good price. I am going to put in in a 1995 4runner. Some of the wiring are cut, no PCM, and no fuse boxes. Most of the wiring are rand new. The motor and tranny only has 16000 miles.
? Is it possible to do that conversion on my 4runer.
? Where can in buy the PCM and the missing fuse box.
? Can the AFM ne disabled.
? Where can I buy the engine mount to retrofit the engine on my chassis
Old May 2, 2017 | 01:13 PM
tokuzumi's Avatar
See answers below. More info on disabling AFM. Looks like you'd need to tune out the check engine light
http://gmtnation.com/forums/threads/...no-cost.13233/
? Is it possible to do that conversion on my 4runer. - Yes
? Where can in buy the PCM and the missing fuse box. - Not sure
? Can the AFM ne disabled. - Yes
? Where can I buy the engine mount to retrofit the engine on my chassis - Not sure if off the shelf parts exist for this particular swap. May have to have something made
Old May 3, 2017 | 12:07 PM
jcvett56's Avatar
You are going to want a standalone harness. At a minimum, a standalone harness only requires a key switch and fuel pump to hook-up. So technically this would work in any vehicle. The AFM/DOD can be disabled in the tune so the vehicle runs in 8 cylinder mode all the time.
We can supply you the wiring ECM and/or TCM, computer, pedal, etc...
-Justin @ Speartech
Old May 6, 2017 | 09:09 PM
Jimbo1367's Avatar
SPeartech does great work and has outstanding customer support.
Old May 7, 2017 | 06:13 AM
kwhizz's Avatar
x 100...........................
