PSI harness only C5 TAC module?
Old May 13, 2017 | 09:18 AM
shanghai_todd's Avatar
Default PSI harness only C5 TAC module?
So what's the deal, I have a HAR1016 harness for my LS1 engine Porsche swap with LS2 throttle body modification but was told I can only use a C5 TAC module and pedal. Really? There is no modification or wire swapping I can do to use a Tahoe or truck TAC and pedal? The C5 TAC module is crazy expensive.
Old May 20, 2017 | 07:52 AM
Anyone?
Old May 20, 2017 | 09:55 AM
Michael Yount's Avatar
Here's a bump for you -- when I was planning my LS3/Volvo swap, I did a bunch of research on the whole 'compatibility' thing. Finally threw up my hands and bought harness/mass air sensor/throttle pedal/O2 sensors ALL from PSI to ensure compatibility. Worked - started on the first turn of the key. Good luck finding your solution.
Old May 20, 2017 | 10:01 AM
Thanks, from what I have been reading sound more like a pain in the *** and uncertainty so I am now looking for a C5 TAC module and pedal.
