Lq4 ECU/wiring help
http://store.haltech.com/usastore/ht-151260-elite-2000-gm-gen-iii-ls1-ls6-non-dbw-terminated-harness-ecu-kit.html
will I be able to run this LS1/LS6 harness and ecu with my LQ4 if I change the fuel injectors to the ev1 style and run an ls6 intake? I've been really confused on what I can and can't do as far as wiring so any help on this would be much appreciated. Thank you guys!
The maf connection may be different as I can't recall and injectors as you already know.
Thanks man I really appreciate you chiming in to help! Will go ahead and pull the trigger on that electrical setup.
