MAF options
Old May 17, 2017 | 08:07 AM
Hart_Rod's Avatar
Default MAF options
I've got the factory MAF for my 2006 Tahoe motor. It's a honeycomb style and somewhat restrictive. What are my options for a different MAF without changing the wiring connector? Thanks in advance.
Attached Thumbnails MAF options-img_20161218_102807_resized.jpg   MAF options-20170314_173952_1489534434696_resized.jpg   MAF options-20170226_200913_1488165956852_resized.jpg   MAF options-20170328_162717_1490753704984_resized.jpg   MAF options-20170328_162828_1490753702072_resized.jpg
Old May 17, 2017 | 08:19 AM
truckdoug's Avatar
Hi Hart! your ride is looking great as always!
so the honeycomb type maf is pretty great as it's not quite as sensitive to turbulence and intake tubing diameter.
you could switch to the ls7 card style maf, but might not want to for the reasons I listed above (i also think some wiring stuff would need to be done, not 100%)
were it me, and I had to have a better flowing maf, i'd use the TSP 100mm maf. it should be a plug in option but you will need to rescale the MAF flow/hz in your tune.
https://www.texas-speed.com/p-660-te...ow-sensor.aspx
whatever you do, dont de-screen the stock one. been there and it's not good.
Old May 17, 2017 | 08:20 AM
truckdoug's Avatar
also, I have to ask what window tint is that in your 'burb. it looks fantastic!
Old May 17, 2017 | 01:53 PM
Hart_Rod's Avatar
Thanks for the info!
Thanks. It's tinted glass that I had a local glass shop cut and temper for me.
Attached Thumbnails MAF options-20170328_162642_1490753707138_resized.jpg   MAF options-20170328_162651_1490753706522_resized.jpg   MAF options-20170328_162700_1490753705762_resized.jpg   MAF options-20170328_162717_1490753704984_resized.jpg   MAF options-20170328_162804_1490753703632_resized.jpg
