4l60e tcc locked up ?
I hope someone can help me out. I have a 2002 5.3 with auto trans swapped into a 94 trans am. Right now the only wires I have hooked up to the car from pcm are fuel pump control,serial data and tcc switch wire. The rest are wired to a seperate fuse panel. My issue is when in gear any gear I have to apply the brake pedal to keep the car from moving and yes I moved the damn idle screw, I really wanted to drive it and was hoping the problem would just go away.😕 When I unplug the trans plug I don't have to hold the brake ,but the car starts out in 3rd . Also if I release the brake when in gear the tcc feels like it releases at 1 or 2 mph. So I checked all my grounds checked tcc switch also took tcc switch off pedal and drove around pressing and releasing button , no change . with everything plugged in the only codes I get are 449 , 452 evaporative fuel valve issues. Another thing, looking at lt1 swap site he says that pink wire on c100 pin c needs power I don't have a pink wire on c100 and pin c has a factory nub in it. And I can't find any wires disconnected, frayed or pinched . I am thinking I am missing some kind of control module for the trans, besides the gear selector module or could it be that I don't have a after cat o2 sensor. Any help would be greatly appreciated.
