Cooling
Old May 21, 2017 | 08:37 PM
Grod67's Avatar
Default Cooling
I'm installing a 6.0 lq4 in.a 55 chev truck 2nd gen. What radiatior hose will I need.? Upper and lower? Part numbers?
Any info would be good
Thanks
Old May 21, 2017 | 09:12 PM
Michael Yount's Avatar
Most of us end up spending time with hoses at the parts store with a tape measure after we've mocked up our end/rad. Without knowing where your engine placement is in the truck, where your rad placement is, where your rad outlets are and what size the rad outlets are - how could we recommend a specific hose?
Old May 22, 2017 | 08:53 AM
Jonas3100's Avatar
If you managed to swap the engine already, I guess finding a hose that will fit won't be a big issue?
Old May 23, 2017 | 05:07 AM
Pop N Wood's Avatar
Not sure if the parts stores in Newfoundland are as well stocked for LS swaps as the ones here in the US
Hopefully someone with a truck can post a pic of what worked well for them. Usually if it works for one it works for others.
