In tank fuel pump
Old Jun 5, 2017 | 11:30 AM
BBButch's Avatar
Default In tank fuel pump
I have LS 3 Crate engine in a 57 Chevy with a Ricks 22 gallon tank.
It started to make noise when I go on trips 75 to 100 mile.
It has a Walbro 255 lph pump.
What I want to know is the part number and or a replacement I can get at a parts store If I need one?
when it cools off it is ok again .
Old Jun 5, 2017 | 12:13 PM
Michael Yount's Avatar
Noise with the Walbros is a pretty common complaint. I went with a DW300 (Deatchwerks) in tank for the LS3 in my car. Flawless performance for 5 years now - so quiet I can't even hear it prime from inside the car. And it should install just like the Walbro does. Food for thought.
Amazon Amazon
Old Jun 5, 2017 | 04:53 PM
Project GatTagO's Avatar
Walbro 255s are crazy noisy. Both the one in my GTO (installed since 2000) and the one in my GTO (installed in 2015) make a lot of noise all the time.
Andrew
Old Jun 5, 2017 | 05:10 PM
Used to have a 5.0L in mine -- the guys on the Stang sites complain about the 255 noise all the time too.
Old Jun 5, 2017 | 08:28 PM
BBButch's Avatar
Have you all seen them go out or they just stay noisy?
Old Jun 5, 2017 | 08:45 PM
The OEM external Bosch pump on mine would go noisy before failing - noise was the primary symptom that a problem was looming. But since many complain about the Walbros being noisy from the start - not sure what to tell you. If it was quiet once - and then gets noisy - that usually points to a problem at some point. But who knows...
Old Jun 5, 2017 | 09:03 PM
BBButch's Avatar
Would you all know the Wilbro part number or any other parts that may fit . I am going to check out the DW 300. thanks
Old Jun 5, 2017 | 09:24 PM
Just google Walbro 255 - you'll find part numbers easily. But you'll love the DW....
 Michael S. Palmer
