Pump reservoir
Old Jun 12, 2017 | 04:44 PM
33willys's Avatar
Michael, thanks for hanging in there with me, talked to PSI today and discovered the ECU was programmed for 30 lb injectors and I have 22 lb. Sent it off for them to correct. Was a very long fight trying to figure out what was wrong.
Old Jun 12, 2017 | 05:33 PM
Michael Yount's Avatar
Hope that's it - sure seemed tune related as the feedback loop kept trying to overcome some fundamental tune issue.
Old Jun 12, 2017 | 06:40 PM
33willys's Avatar
Default Pump
Early this morning I went to Walgreens and got an e-cigarette. Hooked up a smoke system to see where the leak was on the intake (convinced a leak was causing the problem). No leak, and called PSI. He asked about the injectors and I had all the info. That's when we discovered the 30 lb tune on 22 lb injectors. Put a backup computer in and all was fine except the engine seems to be having a nicotine fit. Back to Walgreens for a patch to put on the intake.
Old Jun 12, 2017 | 07:15 PM
Chantix for the tune
