Fuel system gurus--flex fuel ?
Old Jun 6, 2017 | 09:28 PM
Goldhawg's Avatar
Default Fuel system gurus--flex fuel ?
I have two LSx swapped vehicles, but now going a little smaller--like a lot smaller with my latest build--an older Datsun Roadster. I'm swapping in a JDM SR20DE Autech version (kind of Japan's version of Hurst or Shelby) that is hopped up to 200hp crank hp, primarily by running nearly 12:1 compression. So I'd like to run flex fuel to get the higher octane. My question is can I just use a regular fuel pump assembly if it flows a lot more than I'll need? I'm considering the Gen V Camaro fuel pump assembly cuz its short and my gas tank I'm fabbing is only 6" deep. I know the 3.6 in the Camaro will require more fuel than I should for the autech, even on flex fuel. But do I have to use a flex fuel pump?
Thanks for your counsel.
Old Jun 14, 2017 | 07:05 AM
Goldhawg's Avatar
Anybody w/flex fuel knowledge?
Old Jun 14, 2017 | 08:46 AM
JoeNova's Avatar
Restricted User
You can use anything you want, its how long it lasts that makes a difference.
You can use a regular pump, but it might only last 20% of what it would on gasoline.
