pontiac g8 clutchless a/c comp
Old Jun 9, 2017 | 09:09 PM
StatoJase's Avatar
Default pontiac g8 clutchless a/c comp
Hi I have a conversion going on at the moment.
Trying to figure out if the late model clutch-less variable displacement A/C comps on the G8 etc can be controlled by the earlier 0411 pcm and if so a wiring diagram would be great.
There is only 1x 2 pin plug on the compressor towards the rear of the case which controls the stroke I believe.
Part number 4471905700
I have an ls3 going into an Australian torana running the 0411 PCM and 24 tooth reluctor. Reason I am not using the e38 stuff is I already had an ls1 in the works.
I would rather not have to go to the sanden style if possible.
