5.3 Problems with idle. Need Help!
Old Jun 11, 2017 | 11:41 AM
jjamm7667's Avatar
Default 5.3 Problems with idle. Need Help!
Morning, I have a 5.3 in my 71 Monte Carlo. To start it I have to give it a couple of shots of starter fluid.
The car won't stay running unless I put a little load on it while I have a plug in the vacuum port (circled in white).
If I get it started with spray and leave the port unplugged (get a p0106) the car stays on with no load.
Also I can hear my fuel pressure regulator.
Thanks
Am I looking at vacuum issues or fuel pressure?
Old Jun 11, 2017 | 11:52 AM
truckdoug's Avatar
runs good with a vacuum leak...sounds like you need to tune the idle.
google up TPS reset/IAC learn.
you don't even need a programmer to do it, but it's nice to have something to monitor TPS voltage and IAC counts.
Old Jun 13, 2017 | 08:57 AM
jjamm7667's Avatar
Thanks for the reply. What about the fuel pre4ssure?
