Alternator charging by itself...?
Old Jun 11, 2017 | 09:26 PM
8.Lug's Avatar
Question Alternator charging by itself...?
Finally completed my swap, filled it up with coolant for the first time to pressure test it and to find out which wire on the plug I needed to use to excite the alternator. Well as soon as I fired it up, the voltage jumped right up to 13.6v and stayed there - nothing connected to the plug. Using a 10ohm resistor I touched each pin to 12v+ to see if maybe it would do something but nope, it's charging all by itself. Are these self-exciting alternators? I was told they weren't. This is the factory alternator, 2006 GMC Sierra.
Old Jun 12, 2017 | 09:11 PM
8.Lug's Avatar
OK I found out this is the DR44 alternator and is self-exciting that defaults to 13.8v if nothing is connected to it. One pin is for the dash light, the other pin goes to a separate module that can control the voltage but isn't required for the alternator to function. Sounds like the ultimate OEM swap alternator, glad my engine came with this.
Old Jun 13, 2017 | 10:43 AM
Project GatTagO's Avatar
13.6 volts is OK, but optimally you want around 14.2v...Many will say I am crazy, but that's how I roll.
Andrew
Old Jun 20, 2017 | 04:23 PM
oange ss's Avatar
Andrew
especially with high draw fuel pumps, electric fans etc..Connect the L terminal to switched 12v through a 470 ohm resistor or dash charging light (incandescent not LED)
Old Jun 20, 2017 | 06:54 PM
And better yet, also connect the S terminal to the main power distribution point.
Andrew
