Radiator Hose woes
Old Jun 29, 2017 | 12:04 PM
racer442olds's Avatar
Default Radiator Hose woes
Any ideas? 77 cutlass Stock style radiator, Meziere Race Pump with 1.25" upper and 1.5" Lower. Radiator is 1.5" on both inlet and outlet.
Old Jun 29, 2017 | 12:58 PM
JoeNova's Avatar
Restricted User
Go to the parts store, have them take you back to the hoses. You can find a hose for pretty much anything.
Old Jun 29, 2017 | 01:10 PM
pdxmotorhead's Avatar
On custom setups I have had a muffler shop bend the tubing and use short rubber couplers for the final connections when finding a hose didn't work. A muffler shop can also make you a 1.25 to 1.5 adapter out of a piece of 1.25 exhaust pipe. I just sand the pipe to scuff it up and give it a good coat of rustoleum..
Kinda Macgiver buts its worked for me..
Oh and a piece of bendable soft copper works good for figuring out a model to make the final tube with..
Old Jun 29, 2017 | 03:11 PM
Motown 454's Avatar
Napa sells adapters to put on the 1.5 to reduce it
https://www.napaonline.com/en/p/NBG900
They have different sizes Slip it on the the smaller and then put the hose right over it.
Old Jun 29, 2017 | 06:49 PM
Project GatTagO's Avatar
Jags that Run also sell very nice aluminum unions should you want to mate different diameter hose together. I use them a lot.
Andrew
Old Jun 30, 2017 | 12:25 PM
Suncc49's Avatar
Jags that run adapters reduce it... Amazon adapter allowed me to put a steam vent exit and temp sender there
