Which pre filter with external fuel pumps?
I guess something cheap but will work.
Needing 3/8" inlets as it's a 255 pump and I'll use regular hoses on the upstream side of the pump.
Someone said at one time the parts stores may carry them.
Also do we really need to run a post filter or after the pump?
Some injectors are fussy as ****, others not so. ID are very fussy, Siemens less so. If you can get 10 microns or lower post pump, then that should cover most injectors.
And for any pre-filter, ensure it has adequate flow ability given you're relying on gravity. EFI pumps do not suck, nor do they like to try and suck so using a small filter like the Earls one above is not a good idea even if some get away with it.
Bigger is most definitely better here given the volumes of fuel that will pass through it
