Camshaft Identification
Gents, need assistance on getting the real specs of this cam I just picked up. I do trust the guy I got it from. Here is what he told me. It's a used cam and it has this barcode on it. I'll post up a pic as well.
Pro Comp
.580 Intake/Exhaust
.224/.228 Duration
114 LSA
Any info helps, or where I can find. I did a search as well, google and on here.
Pro Comp
.580 Intake/Exhaust
.224/.228 Duration
114 LSA
I don't believe that any aftermarket cams use a bar code. Most engrave the cam. You can also spot a stock cam when compared to any sort of non-stock cam if you have them side by side.
Cam on the left is a stock LH8 cam and the one on the right is a GM ASA cam.
Andrew
Andrew
