LM4 vs Lm7 for swap
I bought an 03 Envoy with 211k. I could hear the engine run and even got to drive it around the guys yard (it was wrecked so no highway driving). I pulled the motor and harness and sold the remainder of the Envoy for more than I paid for it. I wasn't planning on rebuilding the motor but I had enough to install an LS6 cam/springs and have a shop re-ring and bearing slap the block.
Not sure why the LM4 costs more to rebuild than a LM7. My local shop rebuilt my short block and did a valve job for $800. I assembled the heads and long block.
You'd have to swap the parts over.. If your going boost, the LM7 is a cool choice, but if I was staying normally aspirated,
I'd never add the 80 to 100 lbs , the Rainier is relatively light compared to some rigs, you will feel it in the corners, under braking etc.
I'd prb pull the original motor ,, see what stuff looks like then decide on the replacement.
