ls holley efi. stumble help
Old Aug 1, 2017 | 09:31 PM
learning91's Avatar
Default ls holley efi. stumble help
ok ladies and gents i have a fox body 6.0 swap ms3 cam 92mm tb 42lb inj 340 aeromotive pump reg set to 58 psi th400 3800 stall converter..holley efi.. runs good but when giving quick throttle has a nasty stumble , that it recovers from and runs pretty hard...i have had some tuning help from Jason and he has been awsome!! but i havent been able to contact him in about 3 weeks...soooo here i am if i upload my data log will anyone be able to read it? and maybe help me with this problem? thanks for the help in advance!!
Old Aug 1, 2017 | 10:08 PM
LLLosingit's Avatar
Have you adjusted the acceleration enrichment? Can you tell if it's a lean stumble or rich stumble?
Old Aug 1, 2017 | 10:19 PM
learning91's Avatar
no i havent adjusted anything...i cant really tell if its lean or rich..it does recover and pulls hard..if you ease into it..its crisp and clean?..i'm new to all this fun..Jason looked at my datalogs and adjusted my tunes but i'm unable to get ahold of him..sooooo here i am
Old Aug 1, 2017 | 10:28 PM
Project GatTagO's Avatar
If it is a stumble, then it is most likely lean. What does the wideband say?
Also, remember that the base fuel map must be fully dialed in before acceleration enrichment is adjusted.
Andrew
Old Aug 1, 2017 | 10:35 PM
learning91's Avatar
hey Andrew, i have about 1.5 hrs of driving on this since i loaded this tune? not alot of stop n go some just not alot...so i guess i'm not real sure how long it takes to dial in? it really doesnt seem to clean up after driving for 20 minutes..seems the same ..i will have to look at the 02 reading next time i drive to see what its teliing me.. thx!
Old Aug 1, 2017 | 11:10 PM
LLLosingit's Avatar
If you want someone to do remote tune for you las Vasquez has a good reputation on yellowbullet. Not sure what he charges.
https://www.facebook.com/pg/holleyefitutor/about/?ref=page_internal
Old Aug 2, 2017 | 06:40 AM
learning91's Avatar
thanks i appreciate the replys..i just got an email from Jason, so it does look like help is on the way!! thx guys!
