Help with MAP sensor dilemma
Old Aug 12, 2017 | 08:51 PM
Austinbelair's Avatar
Default Help with MAP sensor dilemma
Help! I'm trying to finish up the LS swap in my father's 66 c10. The motor is an 04 LS1 with 243 heads and an LS6 valley cover.
I am installing a cathedral NNBS truck intake on it and running DBW.
The PSI harness calls for a MAP sensor 16212460 or 12614970 so my problem is, the NNBS doesn't take that MAP so do I just silicone one of these into place?
Does anyone know if the NNBS uses the same connector?
I see the number for a 2012 6.2L intake is 12644228.
Old Aug 13, 2017 | 02:28 PM
Project GatTagO's Avatar
The 2012 sensor uses a different connector. You can either get the parts to put the different connector on your harness, or I do believe there are adapter harnesses available. I would not "silicone one of these into place."
Andrew
Old Aug 14, 2017 | 04:41 PM
Something like this?
http://www.ebay.com/itm/24-GM-EFI-MA...1WyRGC&vxp=mtr
