which IAT for speed density?
Old Sep 18, 2017 | 06:44 AM
sean byrd's Avatar
Default which IAT for speed density?
Wrapping up my 5.3 n/a swap. '99 5.3 with '04 pcm/harness. Dbw setup but plan on going speed density since I do plan on boosting it in the near future. is there a particular IAT needed?
Old Sep 18, 2017 | 07:10 AM
Dimeomboost's Avatar
I used the one from an f body I cut the 5 wire mass air flow out of the harness and used the 2 wires that used to be part of the mass air flow and wires up a 2 wire iat from an f body and welded a bung inline to screw it into
Old Sep 18, 2017 | 08:23 AM
ls1nova71's Avatar
I used one from an LT1 car in the Pick n Pull, grabbed the sensor and pigtail with about a foot of wire. You can use a rubber grommet to mount it in the intake tube if going n/a but may want a more secure mounting for boost.
Old Sep 18, 2017 | 11:01 AM
Fast355's Avatar
On the 6.0L I put into a 1987 G20 van, I put a small hole directly in the rear rubber panel of the filter and pressed in a Vortec 350 IAT and connector. Honestly it is probably the same IAT as the LT1 but the Vortec engines 4.3-350 are much easier to find in the yard than the LT1. A lot of mid-late 90s GM FWD 4cylinder and V6 cars use a similar IAT as well.
Old Sep 18, 2017 | 08:39 PM
sean byrd's Avatar
appreciate all the input!
It's pin 25 & 57 from my green pcm connector. just ordered the 2 wire IAT pigtail and I'll prob order a sensor from ICT billet. they've got one with threads for $20 that says it's good for turbo setups as well.
Old Sep 22, 2017 | 08:38 AM
LILHEMI's Avatar
i use this one for my IAT sensor. it works perfect.
Amazon Amazon
and the pigtail for it.
Amazon Amazon
