VSS questions
Old Sep 23, 2017 | 07:24 AM
EricD735i's Avatar
Default VSS questions
Need some help. I’m wiring up my LY2 that’s hooked to a T-5 in an ‘89 Mustang. Trying to figure out what to do with the speed sensor input. I can use the existing sensor from the Mustang cruise control, but not sure how exactly how to wire it. Can it be programmed out without having coast down/idle issues?
Old Sep 23, 2017 | 09:42 AM
garys 68's Avatar
Which T5 are you using? I think most fords used 3 wire square wave sensor, those wont work with the ecu. GM used a 2 wire sine wave sensor that can be wired directly to the ecu.
Old Sep 23, 2017 | 06:31 PM
EricD735i's Avatar
I have a two wire sensor at the speedo cable input.
Old Sep 23, 2017 | 07:45 PM
Michael Yount's Avatar
It should work to provide a speed signal for the ecu to use to help with coast down/idle catch issues. Tune can be altered to adjust that signal so the ecu/bcm outputs an accurate speedo signal - if you need it. Guessing you're using a cable for that though....
Old Sep 23, 2017 | 10:58 PM
EricD735i's Avatar
Thanks. Which pin or pins are used? 71 & 72? It’s an E38 ecu.
