Motor mounts
Old Sep 25, 2017 | 12:32 PM
Rscaamaro's Avatar
Default Motor mounts
Looking for motor mounts and trans crossmember recommendations for the best fit. Ls 6.0 and 4l80e swap in a 1971 camaro and what headers thanks
Old Jan 13, 2018 | 06:14 PM
jkhall's Avatar
Did you ever get the info you were looking for? I have a 1971 Camaro as well and have an LQ4 with 4l60E. Trick flow heads, BTR Stage 3 Cam, WS6 intake and injectors, etc.
I bought the hooker HOK-12512HKR mounts and am not happy with the fact they require changing the lower mount and relocating. I would like an adapter that I can mount my original motor mount onto and it sit on the original lower motor mount perch.
What was your method of mounts?
Old Jan 13, 2018 | 07:10 PM
Rscaamaro's Avatar
I used dirty dingo plates and engery suspension urethane 3 bolt mounts
Old Jan 14, 2018 | 05:57 PM
Project GatTagO's Avatar
The Hooker mounts put the engine lower than regular adapter plates. That's a very good thing...If you don't want to use them, there are dozens of alternatives that work the same way (poorly).
Andrew
