Driveshaft Angle Question - CV Joints
The motor can't go any lower in the chassis as there is only a 1/2" between the oil pan and the cross member currently. I'm pulling everything out this weekend as I need to trim the oil pan a bit. Then on to the diff to see if I can tilt it up a bit.
Thanks for everyone's thoughts. I'll post back.
Cv's are less problematic for driveline joint timing which does help a lot on weird offset drivelines like is being discussed, the angle isn't extreme but they are not in a aligned mode, On a high speed lifted rig you can allow opposite angles if they are the same.. Googling lifted jeep/4x4 drive line, may yield some useful tips..
Trophy trucks are the most radical drive trains out there,, I bet thats the cool source of tech to handle the level of power and such that these cars make.. Of course they almost always use 2 or 3 segment drive lines..
