Truck Harness Question
Old Dec 11, 2017 | 09:53 AM
LS1MCSS's Avatar
Default Truck Harness Question
I'm putting a 2006, 6.0 in my Blazer and want to add pins to the harness for fan control. I know where to add them, but do they put out a ground signal like an f-body? I want to wire them for high and low speed operation. The three relay setups are easy to build and work good. I just need to be sure I will get a ground signal coming from the PCM.
Old Dec 11, 2017 | 02:02 PM
8.Lug's Avatar
lt1swap.com
Old Dec 11, 2017 | 06:07 PM
ls1nova71's Avatar
Yes, they put out the same ground signal as the cars do, but you have to enable them in the tune of course.
Old Dec 12, 2017 | 09:53 AM
gsjimmy's Avatar
Default Blazer?
Is this the S series Blazer or a Full size K-5? lt1tech has the circuit plans for the wiring, uses 3 relays to power the fans. I did the install in a couple hours, not too bad of a job
Old Dec 12, 2017 | 11:14 AM
LS1MCSS's Avatar
It's an 85 K5. I already have the three relay setup built. I have built a lot of those. I just needed the signal information.
Old Dec 12, 2017 | 11:15 AM
LS1MCSS's Avatar
Thank you.
