l99 swap into 1986 c10.
Old Dec 18, 2017 | 02:18 AM
shawnbrown42's Avatar
Default l99 swap into 1986 c10.
I am swapping an l99 into a 1986 c10 while using original fuel tank w/ external fuel pump and regulator, but fuel pump seems to be starving for fuel. Any suggestions?
Old Dec 18, 2017 | 05:38 AM
ls1nova71's Avatar
Get an '87 tank that is baffled and put the pump in the tank. Probably not what you want to hear but it is your best bet. The factory puts the pump in the tank for a reason.
Old Dec 18, 2017 | 07:42 AM
gagliano7's Avatar
If the external fuel pump isn't lower than the bottom of the fuel tank you can have problems. And pulling from the top of the tank is also not a good idea. ls1nova71 has the best suggestion.
