LS Swap HELP
Old Dec 26, 2017 | 05:02 PM
LunarNike's Avatar
Default LS Swap HELP
My current set up is a 5.3 mated to a TH400 with a NP208. I am currently swapping TH400 for 4l60e. My questions are:
Can I reuse my 6.0 flexplate(has spacer from factory) or will I need to get a 5.3 flexplate?
I currently have Dakota digital VSS mounted in NP208, will this work as is?
My tuner tuned the setup I had before with the TH400, will I need tuning with 4l60e shifting or will the PCM still retain its stock shift points?
What wiring will I need to wire up to trans? My current harness is from a red/blue 6.0L with all 4l80e wires depinned. I want to know if it's possible to repin everything(I still have all wires I pulled out) and how to repin 4l80e connector to 4l60e. Also will I need range sensor hooked up? Need to know everything wiring related I need hooked up to 4l60e.
Thanks
