Need Help with WIRING😞
Old Dec 28, 2017 | 06:46 PM
Uglee's Avatar
Default Need Help with WIRING😞
Okay here is my problem.......i have been collecting parts for my lq4 swap for about 6months. Well changed my red/blue DBW harness to DBC. Went to attach it to my pcm ($15 craigslist deal) and the red does not fit. Pcm is green/blue.
If i trim the tabs it will plug in but do i need to repin the harness to the green/blue pcm or can it be fixed with a tune? Trying to start this engine on the stand
Asap!!
Someone pls help me......i just wanna roast some tires in the old 49
Old Dec 28, 2017 | 07:19 PM
ls1nova71's Avatar
They're mostly the same, but you may have to repin a few. You would have to get both pin outs and compare them. Your biggest concern is whether or not your green/blue PCM has IAC drivers in it to work with a DBC throttle body, as not all of them do.
Old Dec 28, 2017 | 07:22 PM
Uglee's Avatar
According to the info on lt1swap.com the pcm "should" work but i will open it right now to find out. Thanks for the quick response!!
