E38 Harness, what can I eliminate?
Im guessing I could disable this stuff in HP Tuners if I remove it, but if I can do something fancy like "turn off the engine if oil pressure goes below xxx" or "adjust rpm or speed limit if transmission temp is above xxx" Id want to retain that functionality.
Does anyone have a good place to point me with what the E38 does with the input for all of the sensors it collects by chance? I dont know how to search for that info well and Im sure its out there somewhere
0.5 TN/WH 585 Transmission Fluid Temperature Sensor Signal (M10)
0.5 BN/L-BU 357 Oil Temperature Sensor Signal (MYC)
What if the PCM doesnt get signal on these? What does the PCM do if it DOES get signal on them? Can I make it where the rev limiter goes ultra low if the oil temp is too high (aka save my engine) for example, because Id want to ensure I got that wired in. If its nothing but a pass through to the gauge, I want it removed.
Here is a list of all the things I think I'd remove, but I dont know what (if anything) I lose from the PCM capabilities if I do.
9 0.5 L-BU/WH 6311 Brake Pedal Switch Signal
16 0.5 D-BU 1936 Fuel Level Sensor Signal
21 0.5 OG 6030 Brake Booster Vacuum Sensor Signal (L99)
24 0.5 D-GN 890 Fuel Tank Pressure Sensor Signal - Pin 1
26 0.5 YE 6111 Clutch Pedal Position Sensor Signal (M10)
31 0.5 BN/WH 6281 Low Reference - Fuel Tank Pressure Sensor Pin 2 & Fuel Level Sensor Pin 3
33 0.5 GY 2709 5-Volt Reference 1 - Fuel Tank Pressure Sensor Pin 3
42 0.5 WH 6110 Low Reference (M10) - Clutch Pedal Position Sensor Pin C
52 0.5 PU/WH 6386 Starter Relay Control
53 0.5 GY 6031 5-Volt Reference 2 (L99) - Brake Booster Vacuum Sensor Pin 3
54 0.5 TN 6109 5-Volt Reference 2 (M10) - Clutch Pedal Position Sensor Pin A
59 0.5 YE 5991 Powertrain Relay Control - PCM controls relay to power up fuses: F5U, F9U, F10U, F7U, F8U
61 0.5 WH 1310 EVAP Canister Vent Solenoid Control
70 0.5 L-BU 1937 Fuel Level Sensor Signal - Secondary
8 0.5 D-GN/WH 428 EVAP Canister Purge Solenoid Control - Pin B
24 0.5 OG/BK 586 Low Reference (M10) - Manual Trans Fluid Temp Sensor Pin A
33 0.5 BN 1174 Oil Level Switch Signal
41 0.5 GY 2705 5-Volt Reference 1 - Oil Pressure Sensor Pin 2
50 0.5 TN/WH 331 Oil Pressure Sensor Signal - Pin 1
What does the Brake Booster vacuum sensor do? I am trying to figure out if I can remove it or not
