Wiring Help!
Old Jan 14, 2018 | 08:38 AM
71Vent's Avatar
Default Wiring Help!
Hello All,
I am in the process of swapping a turbo 6.0/4l80e into a Ventura and am trying to sort out the wiring.
I am going to rework the stock harness for the engine but what body harness should I get?
I have a Vintage Air system going in. I would like to get LCD lights also so the connectors would need to be changed anyway.
Do I need a Speedway Universal 22 Circuit Wiring Harness or similar? Is this overkill?
Eventually I might put power door locks and windows, meth kit, and such.
I just want to get the correct setup.
Thank you!
Bill
Old Jan 14, 2018 | 09:04 AM
DT69cam's Avatar
Why do you need a new body harness ???
Old Jan 14, 2018 | 09:14 AM
jeffs55chevy's Avatar
if your original wiring from the car is still good, you can tie the engine harness into it, its about 10-15 wires if your using lt1swap.com info. if your original body harness is not usable, then i would recommend the speedway harness. its pretty cheap, and nice quality.
Old Jan 14, 2018 | 09:16 AM
71Vent's Avatar
I really don't. The car is very clean. I'm pulling the front end off of it anyway so I was going to run the wiring as neat as possible.
Thanks for the reply!
Old Jan 14, 2018 | 09:18 AM
71Vent's Avatar
Thanks DT69CAM!
jeffs55chevy I am using lt1swap info but I am trying to hide everything.
Thanks again!
