Pulling a Duramax to install a built LS??
Old Feb 9, 2018 | 08:36 AM
Kubitza123's Avatar
Default Pulling a Duramax to install a built LS??
Ok fellas I currently have a 2004 CCLB 4x4 Duramax that is like new and around 550rwhp and 1200tq.
It has a full billet trans etc but has just blown a head gasket. To get this setup where I want it which would be fully built short block, larger injectors , etc I'll be dumping another 10-15k easy. Truck weighs around 7500lbs and I could sell off the aftermarket parts, trans , engine etc and bring in around 10-12k probably.
Im green on LS motors so maybe you can tell me wether to scrap this idea or run with it:
My question is can a reliable 800-1200hp turbo LQ4 or LQ9 be built to run on pump gas for roughly 10k including turbo setup , fuel etc??? Or am I way off and this a 20k build?? I don't need it over built but do want it right and not half as..
I have another truck ill be driving 90% of the time so this will be more of a weekend ride etc. Will a built engine tuned properly etc be good for 50K, 100k? I know there will be maintance along the way but kinda curious if the long block itself would be pretty trouble free if setup correctly?
Its not going to make hot laps at the strip etc . Just a horsepower junkie and like power. I don't flat tear my stuff up but I do like to string it out here and there and lay some rubber down.
I would be putting a fully built 4L80E begins it most likely which I'm figuring $$3500-6k for it.
Anyways let me know if this is a flat *** terrible idea or if it could be done around $15k including trans. Or stick with the Duramax ?
Oh my cousin owns and engine building and Machine Shop so machine work won't cost me much.
Attached Thumbnails Pulling a Duramax to install a built LS??-img_3391.jpg   Pulling a Duramax to install a built LS??-img_3405.jpg
Old Feb 9, 2018 | 11:09 AM
Ach1992880's Avatar
Wow. Let me venture my opinion. Keep this one an oil burner. By the time you swap forged short block $3500, good heads $1,200, turbo system $6,000, trans/converter $3,500, fuel system $1,500?, harness $300, mounts, belts, plumbing, reconnecting a/c, a good tune $600 and add 50% for **** that will pop up along the way if you want everything on the truck to fubction properly for daily driving you will be at $20k in a hurry.
Old Feb 9, 2018 | 11:22 AM
Replace the head gasket.
Old Feb 9, 2018 | 11:48 AM
Michael Yount's Avatar
X3 - and even if you build 1000hp reliably - it’ll have nowhere near the torque curve of the big D - so big gearing changes needed, and even then it’s not gonna move 7500 lbs around like 1200 lb-ft down low will. Anytime you see “and even then” multiple times - don’t do it.
Old Feb 9, 2018 | 12:04 PM
Kubitza123's Avatar
Message received lol. It was just a thought but I figured it would end up cost a little more than I expected.
I already have close to 10k in the full billet trans so guess it's time to do the heads and build the short block.
Thanks for the quick replies so I can scratch that idea.
Old Feb 9, 2018 | 12:13 PM
showdog75's Avatar
Keep the duramax. I own one and couldn't imagine life without it.
Old Feb 9, 2018 | 12:43 PM
kainedogg's Avatar
What he said,
Old Feb 9, 2018 | 12:58 PM
LOL - “Keep the Duramax”.....I don’t own one and can’t imagine life without being able to BORROW one from time to time!
Old Feb 10, 2018 | 12:17 PM
tfi racing's Avatar
Cummins.
Old Feb 10, 2018 | 01:32 PM
truckdoug's Avatar
i dont own or borrow a duramax so yeah you should swap it out. crappy oil burners...all that torque...who needs it?
tell ya hwat i got a pretty baddass turbo six liter and 4l80e i'll trade ya just coz im a nice guy and i like helping people.
