Sn95 hood options
Old Feb 12, 2018 | 09:06 AM
theguyulove2hate's Avatar
Default Sn95 hood options
Hello all,
I'm sure that this has been discussed before, but after searching I can't find out which hood will work for my sn95 swap. I am looking at running an l33 or an l92 with a tubular cross member. I was planning on using a truck accessory drive (mostly because I have one). I was also looking to run the pro-flo XT intake.
I know that the stock hood will not work, and have heard that cowl hood will. I wanted to see if anyone can confirm that, and what size cowl I would need.
Cheers!
Old Feb 14, 2018 | 10:28 AM
No one knows?
Old Feb 14, 2018 | 11:12 AM
Measure how much your intake would "go thru" the stock hood, then measure and see if the cowl hood will fit. A little homework goes a long ways.
Old Feb 14, 2018 | 11:31 AM
Burning's Avatar
New edge and sn95 are built on similar platforms. 2.5" is the minimum needed to clear the truck intakes and alternator.
Old Feb 14, 2018 | 10:31 PM
Awesome, thanks for the help!! I was looking at a 3.5 inch cowl hood, so I should have some room to spare.
