neutral switch
Old Feb 18, 2018 | 04:43 PM
Seeker1056's Avatar
Default neutral switch
I have tried many different searches - not sure if I am not using the right key words or what but can not find what I need
I need the pin out for the one piece plug that goes on the side of a 4l80e that does reverse light and neutral safety, among other things
The pcm wires are easy as they are all numbered from when i pulled them from the pcm.
I want to hook the neutral and back up switches into my car.
I have two shades of green wires, a grey wire and a black white
The black white is ground
can anyone tell me the other three wires - which is reverse and which is neutral
thanks
Old Feb 18, 2018 | 09:24 PM
rpturbo's Avatar
You should be able to find that on the lt1 swap site that has all of the wiring diagrams. They started the 1 pc on 2005 or 2006, so just find a wiring pinout from a 2006 say 2500 with a 4L80e.
I can look it up when I have more time.
