Fuel pump over pressure
Old Mar 2, 2018 | 07:34 PM
Blowncoupe's Avatar
Default Fuel pump over pressure
I have a bosh inline fuel pump with a 04 corvette filter/regulator which should regulate fuel at 58 psi. Today was the first time I started up my ls1 swap and the fuel pressure was 78 psi at the rails. It seemed to run ok has anyone else had a issue like this? I'm assuming it's the filter/ regulator even know it's new . All the fuel lines are new as well so no return line obstruction. Thanks for any suggestions
Old Mar 2, 2018 | 07:41 PM
Sounds like the filter/regulator, UNLESS your gauge is off.... OR, is your return line flowing freely?
Old Mar 3, 2018 | 07:33 AM
cpd004's Avatar
Try taking the cap off of the tank and see if it changes. Could be a venting issue. More likely a slight kink in the line though.
Old Mar 3, 2018 | 12:01 PM
jrz126's Avatar
Any restriction in the tank? Could check it without dropping the tank, just put a hose on the return out of the regulator and have it pump into a gas can.
Had the same issue on mine. The fuel sender unit in the tank had a restriction on the return, cut that off and fixed it.
