vintage tachometer with LS?
Old Mar 9, 2018 | 03:02 PM
GonHuntin's Avatar
Default vintage tachometer with LS?
Doing a swap on a '73 Mustang and would like to keep the factory tach and gauges. I know the speedometer can be converted to electric or a converter used and the gauges shouldn't be a problem.
I have read that the tachometer needs to be set for 4 cylinder but that is not an option with this factory tach, what can be done to make it work???
Old Mar 9, 2018 | 07:41 PM
Modchevelle's Avatar
What pcm? I have a Holley HP and there is a tach output.
Old Mar 9, 2018 | 07:58 PM
ls1nova71's Avatar
Find someone with some tuning software, HP Tuners or similar, and have the tach resolution changed from 6 to 3, that will make it work with an 8 cylinder tach. You may need a pull up resistor to make the signal a little stronger for it to work though.
Old Mar 9, 2018 | 08:05 PM
Michael Yount's Avatar
Feed 12V+ through a 1000 ohm resistor into the tach signal line between pcm and tach - that'll convert the 5V tach signal PCM output to a 12V signal the old tach can understand.
So - two things to do - 1) the change mentioned above to change the signal so it's 'counting' correctly for a V8 tach; 2) the change from 5V output to a 12V output.
Old Mar 9, 2018 | 08:06 PM
GonHuntin's Avatar
Thanks for the info, haven't had the pcm flashed to remove vats yet, I'll ask him to change the tach resolution while he is at it.
Old Mar 10, 2018 | 08:01 PM
Old Mar 11, 2018 | 06:34 PM
GonHuntin's Avatar
I'm running a 411 computer.
Old Mar 12, 2018 | 06:26 AM
If it's a 5V output, the adjustment for your 12V tach is still the same, but the references to wire color/position will be different.
