5.3 with 6.0 heads ported backfire and initial stumble
Hows it going guys I’m new to the Ls world but I jus recently put a stock 5.3 with 6.0 heads ported in my 79 Malibu and I am gettin backfire and initial stumble when you give it full throttle, other than that it runs decent.
Eveythings stock besides edelbrock intake and msd 60143 box, I put it on computer (msd view) and changed map/timing a tad, by going off a YouTube video and it seemed to help a bit but other than that I’m lost.... should I put 5.3 heads back on or go with bigger cam..?
Thanks for any help/suggestions
Do you mean the fuel/air mix screws on the front of carb, changing jets, or puttin a 50 cc accelerator pump in it ( I heard of someone doing so on another thread) other than that its a brand new edelbrock carb 1806 650 cfm, I haven’t done nothin to it besides bolt it on...
thanks for the reply.
cant seem to find any vacuum leaks, but thanks I’ll look at that accelerator pump rod today and see if I can figure something out... I’ll hop back on later
Thanks again , appreciate your time n suggestions
<Motor seems choked out at full throttle, but I can gradually power brake it and turn tires like nothin>
