ls swap with a 4l60e
Old Apr 7, 2018 | 06:02 PM
Harolds64impala's Avatar
Default ls swap with a 4l60e
Hi im doing a 64 impala 5.3 ls and 4l60e transmission, i need to know what i need to do to get for this 2 to work correctly. i have the engine harness and also the transmission harness which came out of a 4wd tahoe. i need to find out who can flash computer and what else i need to do. thanks for your help.
Old Apr 7, 2018 | 07:25 PM
MaroonMonsterLS1's Avatar
If you have the full pullout engine and trans, the computer side of things should be a snap. You'll just need someone to flash out the VATS system, and probably adjust gear ratio/tire size so it shifts properly. Maybe turn off catalytic converter codes if you arent using them.
BUT, since you have a 4wd 4l60e, you'll need a complete teardown and rebuild in order to be able to change the output shaft to a 2wd unit. You'll also need a 2wd tailhousing.
If you have it apart, you should really do some basic upgrades. What year is the tahoe combo?
Old Apr 7, 2018 | 07:31 PM
B52bombardier1's Avatar
Your driveshaft will also likely need to be shortened and the front yoke probably changed depending on what the vehicle had for a transmission before. Your trans cross member might also need to change.
Engine mounts? Probably also need to change. Your 5.3 exhaust manifolds also might not work in your vehicle - headers might be needed.
Rick
