F Body advice needed
Old Apr 9, 2018 | 08:29 AM
kochevy67's Avatar
Default F Body advice needed
So I am putting an LQ9 into my 16 year old sons 1980 Trans Am that we recently acquired. I have a few questions on this to make life easier. I am dropping the engine off to have I freshened up at a machine shop. I was thinking of going with the Holley Sniper tank ( the car has been sitting since 1998 so it needs a new tank), as far as exhaust and front drive brackets what do you guys recommend. And lastly will Pontiac frame mounts need to be changed to bolt up the LS engine. I am running a 4L80e behind it. Any input is appreciated. I haven't done an F body, I did my A body Chevelle 8 years ago and things have changed drastically. Thanks
Old Apr 9, 2018 | 10:23 AM
Check out the Holley website for EVERYTHING you will need to swap the LS engine in. And you will need mounts.
Old Apr 9, 2018 | 06:35 PM
kochevy67's Avatar
Do you know if the frame mounts from the Pontiac will work or do I have to buy different ones? I have been researching Holley and it looks like they have it covered pretty well.
Old Apr 10, 2018 | 12:41 AM
The Firebird and Camaro subframes are the same, just using different engine mounts for the respective engines. You remove the Pontiac mounts and bolt down the Holley ones.
