fuel regulator with rail return
Old Apr 15, 2018 | 06:24 PM
wildman8448's Avatar
Default fuel regulator with rail return
I have a truck LS engine going into my 26 dodge. Actually it is already installed. I am ready to put an inline fuel pump.
The fuel rail has a return line. Does that mean I don't need an inline fuel regulator like I have on my other LS without fuel rail return?
Old Apr 15, 2018 | 07:53 PM
B52bombardier1's Avatar
No, you still need a regulator. I think your best course of action is to cap off the return at the fuel rail and use the usually short return line when you install the regulator close to the fuel tank.
Rick
Old Apr 15, 2018 | 08:21 PM
brandon6.0's Avatar
Are u using a stock gm return fuel rail setup?
If so add your fuel pump inline, thin into fuel rail feed. Return from rail to tank. The stock oem fuel psi regulator in the fuel rail will work perfect. No need to aftermarket regulator or corvette filter/regulator.
Old Apr 16, 2018 | 01:43 AM
ls1nova71's Avatar
Do this! Don't see why so many people are bent on using Corvette filter/regulators when their engine already has one. You can just use a regular EFI rated filter and be done.
