LC9 swap to non AFM
Old Apr 25, 2018 | 10:13 AM
plxman111's Avatar
Default LC9 swap to non AFM
Would like to swap Chevy LC9 Gen 4 from 2008 avalanche 4x4 with non AFM LM7 Gen 3,reprogram ECM.
I know it will lose 25hp. Problem is the 24 tooth vs 58 tooth reluctor wheel on crankshft...any ideas on who offers long block with this feature
Old Apr 25, 2018 | 11:39 AM
You can't reprogram a GenIII ECM to a GenIV or vice-versa. They are completely different processors.
If I have this wrong, you might want to more fully explain what you want to do.
Old Apr 25, 2018 | 12:35 PM
plxman111's Avatar
Simply put, wanted a crate motor with the AFM delete already performed 2008 Chevy Avalanche 5.3l Engine code LC9. (easy engine swap)
Going to perform AFM delete on existing motor, camshaft,16 lifters, oil pump and timing chain.
