Power Steering leak
Old May 15, 2018 | 10:35 PM
mrfleet12's Avatar
Default Power Steering leak
Hello
I recently completed my LS2 swap into my 73 base Camaro and I'm running a Corvette FE. Everything has been working fine but I noticed a small leak of PS fluid, there aren't any air bubbles in the system and it's not over full, yet, it seems to be leaking from somewhere. It looks like it could be the the pressure hose fitting in the pump or is looks like it could be coming from the cap.. After some researching of this site and others, some mention using a Borgeson kit to reduce the pressure some, which in turn, reduces the heat in the pump as well as the pressure.
Has anyone use this kit or done anything else that reduces the pressure enough to eliminate the issue?
Any help would be appreciated..
