Eldorado/Seville e-brake
Old Jun 13, 2018 | 07:36 PM
epfatboy's Avatar
Default Eldorado/Seville e-brake
C10 LS Turbo conversion getting disc brakes. I bought the 85 Eldorado rear calipers with e-brake.
Looking for a little advice on how to adjust the e-brake? Bled the brakes and they are working well, the e-brake however is not. I have worked the e-brake pedal a few time but no change to the brakes grabbing.
Old Jun 14, 2018 | 06:59 AM
kwhizz's Avatar
Worst Brake design ever...……...Better off getting a set-up with expanding drums and getting it right !!!!!...……...Been There...…
Ken
Old Jun 14, 2018 | 08:34 AM
gofastwclass's Avatar
I wouldn't call it the worst ever, have you ever driven a vehicle with mechanical brakes? Hahaha!
Ken is right on getting different rear brakes. The design of the parking brake on the Eldorado calipers is terrible.
For factory parts I personally like 1998 to 2002 F-Body rear brakes as they are simple, reliable and easy to come by.
Old Jun 15, 2018 | 10:08 AM
jozw30's Avatar
Call CPP tech and ask for the correct adjustment procedure. I looked but couldn’t find it. You have to pull the arm/lever and use a wrench not just swing the arm back and forth.
The instructions that come with these kits suck.....
They are fine once adjusted. But until you do it right I’m surprised you got brakes at all.
Old Jun 15, 2018 | 09:09 PM
epfatboy's Avatar
I know they suck, I'll rarely use them but I need to have them for an Inspection.
I got it done, little weird. I could not get them to adjust using any procedure I found online. What I did was remove the lever, rotate the adjusting nut 1/4 turn, and reinstall the brake lever... that worked sweet. Brakes and parking brake work perfectly now.
Old Jun 16, 2018 | 09:51 PM
toplessHO's Avatar
no the ones used on the earlier sevilles and same era trans ams are worse
even the dealers mechanics at that time wouldnt mess with them.
you must used the e brake almost every time you drive it to keep it properly adjusted
Old Jun 19, 2018 | 06:44 AM
kwhizz's Avatar
Bingo !!!!!!!!
Old Jun 19, 2018 | 07:24 AM
ZEN357's Avatar
Had same issue on a 2003 Buick Regal. Couldn't get the e-brakes to work right. Had to take it to a shop to get them to adjust them right.
 Michael S. Palmer
