Is my alternator dying?
Old Jun 22, 2018 | 12:36 PM
cpd004's Avatar
Default Is my alternator dying?
It seems to be charging erratically. I'm guessing the regulator is going. This is an OEM 11 Corvette alternator.
Old Jun 22, 2018 | 05:53 PM
B52bombardier1's Avatar
Seems to be rock steady at 14.2 volts DC. Does it read anything for AC volts that might indicate leaky diodes in the rectifier?
Rick
Old Jun 23, 2018 | 09:16 AM
cpd004's Avatar
Good question. I'll have to use a different meter to see. I see it is consistent, but my thought when I saw this was that maybe the Power Probe isn't sensitive enough to show a very fast split second drop.
Old Jun 23, 2018 | 05:50 PM
What happens when you increase the engine RPM? What happens when the fans and air conditioner kick on? Your 14.2 VDC number is about what I see at idle when my radiator fans and fuel pump are running. About 14.4 VDC without the fans running. I don't yet have anything else electrical running on my El Camino but will someday.
Rick
