Lsx swapped 94 z obd II
Old Jun 28, 2018 | 10:51 AM
Blac94z28's Avatar
Default Lsx swapped 94 z obd II
good morning in the middle of swapping my engine and trans in to my 94 z now I’ve just gotten to the wiring portion and I’m a little confused, I’ve searched high and low but I cannot find an accurate answer so here we go, now my Camaro is currently obd1 now in order for me to swap it over will I need to change my wiring under the dash or will I be able to simply just cut the obd1 port from under my dash and install the obd2 port with the wiring running to the correct pins ?
Old Jun 28, 2018 | 10:59 AM
merim123's Avatar
i have a 94 with lsx obd2. I repinned and used in c200/c210/c220 and I think I had to run one more wire. bring the wires you need to the OBD2 port. I kept mine in the c200+ connectors so it's always plug and play.
