LSA into 07 Chevy
Here's my question/problem. I've got an GM LSA Engine and Trans with a stand alone ECM and TCM from GM going into an 07 chevy 1500. From what I can see is Both the ECM and the Vehicle have the high speed "LAN" Communication system, and i'm wanting to see if the stock gauges will work. I'm not sure if i can just tap the new ECM LAN connections into the original ECM LAN connection and everything will work or will there be a need for programming? I'm hoping the ABS, BCM, etc. will keep working and the ICP wont look like a Christmas tree.
Thank you in advance for any and all help, it's the first time i've done a project like this.
The truck originally came with the 5.3 and 4l60E.
I was also told to use the stock harness and ECM and get it tuned, but there are a lot more sensors and none of the trans will plug into the old harness...
what do you mean by none of the trans will plug into the old harness? 4l60 and 4l75 should be pretty close to the same with exception of some later versions having an input speed sensor iirc
if it is ready to fire, i say go for it...some of this stuff you just have to try and see if it works. might be better to figure some things out having the motor/trans standalone...then you can know that they're operating as they should before connecting them to the rest of the truck (at least the data communications). if you haven't done a swap with the gm high/low speed lan before, just make sure you have the loops properly setup, (its pretty easy to get the wires confused) and also the terminal resistor that is needed which is sometimes part of a module that may not be present so you just add one externally. sorry if you know this stuff already
for what its worth, i have a project that i'm using a pcm, bcm and gauges from three different vehicles (different platforms) and have got the motor running without programming anything and the gauges seem to work for the most part though there's alot of lights going for the different modules that are missing.
